She's finally running
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blackwidowk5, Feb 9, 2001.
  1. blackwidowk5
    blackwidowk5 1/2 ton status
    Dec 1, 2000
    107
    Richmond, Virginia
    She\'s finally running
    Well after two months i finally have my blazer back. I just got finished doing a major heart transplant. THe new heart is a smoking 350 with vortec heads, roller cam, edelbrock intake and carb, msd ignition, headers and a flowmaste. I forgot what it was like to be able to accelerate again. Anyways i thought i'd share, next project, new interior.
    p.s. The jets on my carb aren't the best, anybody have any idea what i should use or could point me in the right direction, Edlebrock 750 manual choke
  2. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Re: She\'s finally running
    Sounds like a great combo... I believ Edel has metering rods... the carb is probably running a bit lean... depending on what pistons and compression you have. I'd guess jumping up 2 sizes.
    1987 Chevy K5 Blazer- 350 TBI
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    Congrats!!!!
    Have you installed the off-road kit in your Edelbrock(if it is not a q-jet).. These help out a lot. Not sure on the jets though.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Just thought I,d throw these at ya.
    Symptoms of a lean carb: backfiring or bog on accaleration, surging, Spark plug electrodes white or light grey (should be light tan). The spark plugs are the best way to tell if your mixture is too lean. Also make sure there are no vacume leaks. If the carb is way too lean you can burn a valve.
    Symptoms of A rich carb: rough idle and misses, Spark plugs fouled with black soot or wet with gas. Black smoke out the exaust pipe. Bad gas MPG
    You should be able to get a jet and meetering rod kit from Edlebrock. Or try a local speed shop. Summit or Jegs on line also have them.
