She's gettin there
Discussion in 'The Garage' started by 5trucks, Feb 26, 2007.
  1. 5trucks
    5trucks 1/2 ton status
    Aug 12, 2005
    169
    Yuma Az.
    Finally got the 2wd box mounted and figured out. Here are some pics for you to critique. Let me know if i need to fix or move something.
  2. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Only thing I see wrong is its on your truck and not mine.:D
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I don't think the pitman arm nut is tight enough. Did you clean all of the paint of of the arm and the sector shaft prior to assembly? It has been my experience that there should be threads showing past the nut.
  4. 5trucks
    Aug 12, 2005
    169
    Yuma Az.
    Good eye. Everything is just finger tight right now. Wanna put the hydro assist ram on before i tighten it all down.
  5. 5trucks
    Aug 12, 2005
    169
    Yuma Az.
    Made a little more progress and i hope to take her out for a little play time on sunday. Still a few things i need to finish but the major stuff is done. Gonna do some " X's " for where the doors used to be and bleed the brakes. Minor things. Give me some input on things you thing may need changing.
  6. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    whose crossover set up did you go with? looks good. i need a new draglink
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Look at it a little closer.... WFO. :wink1:
  8. 5trucks
    Aug 12, 2005
    169
    Yuma Az.
    WFO on the drag link (went with the shorty tie rod ends.), steering arm. The pitman arm is for a heep and Trevor sold me the arm that would be best suited for the pitman arm. It's really well made stuff. Props to WFO for the steering and GLO for the beadlocks.
  9. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    Are you running a 2" ram for your hydro assist?
  10. 5trucks
    Aug 12, 2005
    169
    Yuma Az.
    Yes! I always seem to run that type of ram. Not the fastest response when making quick turns but it works pretty good. Mine is gonna end up being a trailer queen i think anyway.
  11. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    are you running the steering box brace or taking the "cross your fingers and hope the box doesn't rip off the frame" approach? the ram will take stress off the frame but its an old saying cause its true. "Better safe, then sorry"
  12. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
  13. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
  14. 5trucks
    Aug 12, 2005
    169
    Yuma Az.
    Yeah, i have the bolt on brace. I'm sure it will suffice but if i need too i'll get the weld on thing later on. Hoping for the best right now. Anyone see a problem with the exhaust dumping real close to the right side of my 14 bolt? I can move it but i'll leave it if it's not gonna hurt. I dont want it to make the housing to hot.
  15. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    If you are doing it you should add the weld on frame repair kit now before it becomes a problem.
    Personally we did not! I checked my frame frequently for cracks before and after the hydro assist install, but sure enough maybe a year and a half with hydro assist my frame started cracking.
    Other than that looking good!
  16. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    Mine's Braced But Not Welded No Ram Box Tore Big Hole In Frame - Caveman Dave
