shift indicator? cable
Discussion in 'The Garage' started by FlatBlackBurb, Apr 19, 2007.
  1. FlatBlackBurb
    FlatBlackBurb 1/2 ton status
    Mar 23, 2007
    390
    Santa Cruz, CA
    okay so the little orange thing that shows you what gear you're in broke off so i replaced it. I put the new one in, but i can't seem to find out where the shift cable attatches to on the steering collum. i know what you're thinking. "why didnt you just look where the last one was attatched?"
    well the last one wasn't attatched. maybe the whole thing is broken. anyways what am i looking for?
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Ok, it attaches to the lower most piece of the column that rotates when you move the shift lifter. Here is a pic to help show you. Look upward just about where the steering column bolts to the dash. It mounts to the right side of the column. [​IMG]
  3. FlatBlackBurb
    Mar 23, 2007
    390
    Santa Cruz, CA
    thanks dude. ill go out and try it right now
  4. dyeager535
    26,975
    To clarify, if you didn't find it,there is a slot cut in the plastic sleeve (that turns, as mentioned) and the metal clip fits over that. The slot is so you can adjust it correctly.
  5. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Not all columns have a slot. There were two different kinds of indicators, one had a clip with a screw and that column will have the slot, then there is another indicator that only has a clip and that column will not have the slot but either way will work.
  6. FlatBlackBurb
    Mar 23, 2007
    390
    Santa Cruz, CA
    okay maybe im missing something but nothing is moving when i shift it. can someone send me a picture? thanks
