shift indicator, need help.
Discussion in 'The Garage' started by mr_fujisawa, Feb 8, 2004.
  1. mr_fujisawa
    mr_fujisawa 1/2 ton status
    Sep 1, 2003
    288
    SF CA
    i just got a shift indicator and i can't figure out where to mount the clip that is on the end of the wire. do i need to disassemble the steering column to attach it to something inside? am i missing some part? please help.
    sean /forums/images/graemlins/dunno.gif
  2. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    there is a lip that runs all the way around the column. wrap that clip around and down and slide it on the lip - somewhere around the 4 o'clock position. there should be no slack in the small wire. as you pull down on the gear selector to run through the gears, the column rotates clockwise and pulls the clip with it. as the clips gets pulled down and away the orange pointer moves to the right...
  3. mr_fujisawa
    Sep 1, 2003
    288
    SF CA
    i did that and it went alright from P -> R -> OD -> D and then it wouldn't move to 2 or 1.
    i think i was doing something wrong. it seemed to bind up as it got to the drive position.
  4. mccomas
    May 30, 2003
    262
    Fayetteville, NC
    i think that there was a small metal guide that the wire routed over - also ensure that you have the right spring. if you cannot get it worked out, shoot me a pm and i will go snap a pic after work on monday to show how mine is routed...
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    [​IMG] The metal tab goes where green arrow is, red shows the path the metal wire should go. Hope that helps.
  6. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I looks like to me that part of the POS green plastic is missing. Mine broke, now I just have to shift by feel. /forums/images/graemlins/grin.gif
  7. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Yep, your missin this piece...
  8. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    mine to..its just kind of nice to have working but dont really need it ur nothin.. /forums/images/graemlins/smirk.gif
  9. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    When mine broke, I replaced the plastic piece the cable rolls on with a screw and a bushing. I just screwed it right into the dash -- works great.
  10. mr_fujisawa
    Sep 1, 2003
    288
    SF CA
    ah you are a genius! i will have to copy that idea! /forums/images/graemlins/thumb.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/waytogo.gif
  11. mr_fujisawa
    Sep 1, 2003
    288
    SF CA
    ok, so i did my own little bit of rigging today with a screw eye and broke my speedo in the process [darn] that sucks. /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
    the screw eye from afar:
    the screw eye close up
    broken speedo. can i get a new needle on this thing somehow, or do i need to replace the whole unit?
  12. wk96
    wk96 Registered Member
    Jul 7, 2009
    26
    Orlando
    does anyone have the images relating to this? I'm thinking the guide broke off on mine, but I'm not positive where the best place to put a screw would be to serve as a guide. images aren't loading, I'm assuming because they're dated.
