shift into 4wd without stopping forward motion. anyone crazy enough to try it.
Discussion in 'The Garage' started by vortec, Dec 6, 2006.
  1. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    so, has anyone here tried shifting into 4wd while in forward motion on the street? maybe around 40+mph? i'm not saying i plan to. i'm just curious if it would actually engage at that speed, and if it would break stuff all to hell.
  2. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    I know I can do it with a 208 T-case. You have to let off the gas. Its a neutral torque setup.
    But the real question is "Why the hell would you shift in to 4 wheel at that speed?"
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I shift my 208 into 4HI at speeds of up to 35 MPH all the time......
  4. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    My friend did that on his 97 Dakota and it sarted making all sorts of grinding and popping noises. Not good
    But as long as you don't go to 4lo you should be fine.
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I do it all the time but I have a NP241 Xfer. I can shift in and out of hi range 4x4 at most any speed. As said you can do it wiuth 208 too.
    Acually if you work on letting off the gas. and pull the lever at the right rpm you can do it with most any xfer case but it takes some practice with some. Knowing how to double clutch helps.
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    When I was in highschool and DD the K5 I could beat just about ANY car at my school off the line.
    Thats with a crate 350, 35" tires, 700r4, and 5.13 gears:D
    Id start out in 4wd to keep the tire spin to a minimum, then shift into 2hi for the finial climb to 6k:D
  7. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    ive done it under 20mph quite often.
  8. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    make sure your hubs are locked in when you do it. Ive done it many times before, maybe not that fast but driving through a field just before we would get to a slick spot let off the gas and yank it in.
  9. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    well theres a difference between shifting into 4WD, and shifting into LOW RANGE...
    any transfer case will let you got from 2 <-> 4 on the fly if the hubs are locked.... I do it all the time on pavement at 60mph+ with a np205..
    range changes on the other hand.................................
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The aluminum cases are synchroed for hi range , but low range is a no no .
  11. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I always stop when I put mine in 4wd. Than again I have to get out to lock the manual hubs.....
    -Harrison
  12. Cajun4x4
    Cajun4x4 1/2 ton status
    Oct 17, 2005
    889
    Lafayette, LA
    did it at 55... still in one peice :wink1:
  13. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    x2. I do the same when we are just playing in slick top mud. Run it in 2wd and if I bog down I pop it in. Now if its real mud I just go 4wd all the way.
  14. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    With my DD i just pop it into 4hi no problem at high speed but never gone over 30 wen doing it. 4lo i stop put it in nutral then 4lo then drive bam all good.
  15. goldwing2000
    goldwing2000 Guest
    x2 As long as the hubs are locked in (and you're not on dry pavement! :eek1: ), it's no big deal.
    If I'm driving on partially snow-covered roads, I'm in and out of 4wd all the time.
  16. vortec
    Jul 22, 2004
    1,472
    fort worth, texas
    yeah, i never planned on slapping it into 4low at cruising speeds. however, the reason i originally made the post is that we've had some icy weather, here (not much), and i hit a big patch of black ice, on a road that sloped heavily to the right. to get little more control, i went into 4hi by going neutral/4hi/drive. now i know i could have just plopped it straight into 4hi. good info to have for the 2 days a year that we have ice here. :haha:
  17. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i've seen 2 come apart at highway speed, but they were in S-blazers, so probably a different transfer case altogether.
  18. PeteH
    PeteH 1/2 ton status
    Mar 26, 2003
    498
    San Jose
    is there a way to make it so you can safely do it 2wd to 4wd at high speeds from in cab? some short course trucks(i think prolite trucks) engage 4wd in corners and then 2wd all the rest of the course(i think)
  19. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    The owners manual for my 70K5 says you can go to 4H at any speed. However, I challenge anyone to shift a D20 T case to 4 H and still keep it on the road(damn J shift pattern).
    The manual also says not to engage 4 wd when the rear tires are spinning faster than the front tires.
  20. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    High range is a no brainer - I've done it at 60+ with every 4WD I've ever driven.... ones with 203's, 205s, 208s, whatever was in our old '96 1/2 ton Chevy and whatever is in my '05 Dodge 3500
    Low range you should come to a complete stop and put your tranny into neutral first.
    Mike
