SHIFT KIT
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JORGE, Mar 12, 2001.
  1. JORGE
    JORGE 1/2 ton status
    Jan 10, 2001
    213
    VITORIA-GAZTEIZ(ALAVA)BASQUE COUNTRY,SPAIN
    HELLO,
    I HAVE AN OTHER QUESTION(YOU,RE GOING TO HATE TO ME!) HOW IS A SHIFT KIT?,A FORUM FRIEND YESTERDAY SAID TO ME , THIS IS A GOOD REMEDY WHEN A TRANNY SLIPS.IS EASIER TO INSTALL?HOW IS?
    THANKS AGAIN.JORGE
    COKE160@LATINMAIL.COM
  2. dyeager535
    26,982
    191
    Its not a good remedy when a tranny slips. When it slips, its because its worn. Nothing short of a rebuild will fix that. Depending on the kit (I consider trans-go to be top of the line, B&M bottom, due to the instructions and parts I have seen) installation will be moderately involved, taking apart some of the transmission. It can be done, and millions of people do it on their own.
    Dorian
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    A shift kit will not help a slipping transmition. It only firms up the shifts and gets rid of the overlap. They are easy to install (just remove the pan,valve body, drill some holes bigger, and reinstall with the new parts)
    '71 Blazer CST with alot of rust
