Shift kits: B&M or Transgo?
Discussion in 'The Garage' started by NITRO, Dec 7, 2002.
  1. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    which one is better?? B& or transgo?? i just want firmer shifts, but dont wanna spend alot of time on it, but i will if it is worth the quality. thanx for the opinions
    NITRO
  2. carolina custom
    carolina custom 1/2 ton status
    Dec 29, 2001
    161
    Mt. Pleasant SC
    I have had good luck with Transgo.
  3. muddysub
    Jun 23, 2001
    10,454
    493
    my garage, Henderson, NV
    i've heard transgo is better.
  4. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    how long did it take u to put the kit in a th350?? can u pick between the two modes on the B&M's or does it just depend on which combination of parts u put in??
    NITRO
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I've always used TCI.
  6. carolina custom
    Dec 29, 2001
    161
    Mt. Pleasant SC
    It should take you 1-2hrs the first time you do it, if you dont loose one of those check balls /forums/images/graemlins/rotfl.gif.
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I usely put in a shift kit when I rebuild the transmission. It's so much easier with the tranny up side down in the bench !!!!!!!! Plus I like to use all heavy duty (good) parts when rebuilding.
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    go with the transgo /forums/images/graemlins/thumb.gif
  9. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I've heard nothing but good things about transgo.
    The B&M kit is good for the TH350. I wasn't really impressed with the TH400 kit.
    I installed a B&M stage 2 street/strip kit in my blazers TH350 and i love it! Takes maybe an hour to do the shift kit. Chirps 2nd some of the time. I've even gotten it to chirp 3rd a few times. If you don't want that then tame it down with a stage 1 kit.
    The differnce between the stage 1 and 2 is the directions tell you where to drill holes in the spacer plate. Its in different locations according to which you want.
    I heard some people say the directions suck but i thought they were easy.
    Don't lose the check balls when you take out the valve body with the tranny still in the vehicle.
    When it's time to reinstall it, you'll want to get some tranny assembly lube or maybe just a small amount of some grease to hold the check balls in place while you line up and bolt the valve body back on.
  10. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I have a stage 2 B&M shift kit. I have no complaints about the quality of it. I should have went with stage 1 because it absolutely slams into 2nd. My 35's and 4.56's always chirped into 2nd and sometimes 3rd. I also run 39.5's now and it ain't cool anymore because all you get is a big slam into second because those tires don't chirp too easy.
  11. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
  12. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Poll the respected trans shops in your area. If one of them recomends B&M, check into if they're really respected. None of the respected trans shops in these parts will use any interanl parts from B&M.
  13. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Got to thinking about it. "Fairbanks" make a good shift kit also !!!!!!!!
