shift kits-good or bad
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by XHitman396, Feb 12, 2003.
  1. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    well i been thinkin and would a shift kit on the 87 700 r4 be a helper, it would be the one for rv/tow or whatever, and i heard that they can be bad on a 700, whats your opinion...thanks..
  2. VitaminK5
    VitaminK5 Registered Member
    Feb 11, 2003
    6
    NJTPK Exit 11, NJ
    Take the strip version for control of choosing and holding the shift point. Had two of them already both were B&M kits. Do it clean and well lit and they're not bad at all. On the truck it didn't make any difference besides holding the gear for me when I wanted it. On the mustang it was like someone putting me on a catapult through 1st and 2nd. 3rd to 4th was regular in my opinion. No damage or quicker burning fluid.
  3. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    I have one in my 91 and the only complaint I have is that it downshifts hard into 1st when running in drive, which I do most of the time.
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    A moderate shift kit will make the tranny last longer.
    It gets rid of the slipping of the clutches between gears that causes them to wear. A HD/RV shift kit and a big tranny cooler is how they should have come from the factory!
  5. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I put a stage one setup in my 700r along with the biggest cooler I could find.....My A/C condenser /forums/images/graemlins/eek.gif And so far it work just find for me.
    I did read where someone had put a stage two in his 700r and if I remember right he had problems with something damn if I can remember what right off hand sorry.
    Eric
  6. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    My local tranmission shop would not offer a warranty on my 700r4 rebuild without a shift kit and a auxilary cooler. works well, 85,000miles so far, (my original died at 70,000) the only thing I've noticed is an occasional hard downshift.
  7. mudober
    mudober Registered Member
    Feb 19, 2002
    23
    <font color="blue"> </font color> I have the b&amp;m rv kit in my 700r4 also.Like some of the others I get a hard downshift and also a hard 1-2 upshift.I think its hard on my driveline.If I had to do it again I would just go with a good quality stock kit with asbestes linings.
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I had one put in my tranny when it was rebuilt...it shifts hard into 2nd when its cold, otherwise i love it...as far as it being hard on the driveline, it might be...my rear end (10 bolt with 145k at the time) took a crap right after i had it rebuilt with the kit though...maybe it was just its time, or maybe the shift kit killed it, i dont know
  9. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I've heard its not good for them to out a shift kit in an old tranny, with a lot of miles that hasnt been rebuilt...with a rebuild though it should be fine
  10. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    Hard on driveline ...NO, ujoint yes, a "little" but as long as it's under load it's not bad at all! This is from a builder who has been doing it for 50 years!! He wont build one with out a mild kit and guarantee it, BUT he doesn't add plates he adds a few balls in valve body and or removes a few balls. Also changes servo and uses a vacum modulator from a diesel with the same tranny, via th 350 or 700r4 etc. /forums/images/graemlins/rotfl.gif
  11. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    mudbogAD has a B&amp;M stage 2 in his th350 and with 4.56s and 35s he could chirp em into second. but now that the WOW factor is gone, he doesn't like it, hes goin to a stage 1 soon and so am i.
  12. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I put a B&amp;M stage 2 in my TH350, with 3:73's and 35's it'll chirp going into 2nd sometimes.
    Maybe i'm "hardcore" but i love the snappy shift into the next gear in my auto trannys. It's exactly what i wanted. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  13. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    In high school I had a 305 z28 that had 115k on it when I put a shift kit in.It was a B&amp;M stage 2. It held up to high school kid stupidity until it was stolen with 135k on it. It still shifted great, and the fluid wasn't burnt until the entire car was by the theives.
    I have heard a shift kit adds to tranny life by reducing slippage.The only things better are fluid changes and an effective cooler.
  14. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Are shift kits good or bad......The answer is both/it depends. Firming up the shift will reduce the amount of clutch slippage which will reduce heat and help save the fluid (as well as less wear on the clutches), but as in everything, moderation is the key. Depending on what you have in front of the tranny, and or behind it, a shift that is too quick or too hard can affect other parts of the driveline (u-joints, rearend, tranny interals, etc.). Hard shifts can be tough on sun-gears, input and output shafts, etc. and can actually lessen the life of the tranny, unless other parts are "beefed" as well.
    A Mild shift kit (mainly pump and valve body modifications) will help just about any tranny, but when you start getting into "heavier duty" mods, it will depend on the rest of the components as to whether or not it is good.
    For a Stock 700, I would say go mild and add a good cooler, and possibly a remote filter. They are a good tranny, but not the best (especially in stock form). Also the year of the tranny (700) can make a big difference. Doing a search here and online will give you some good info on which years are better than others and why (mostly input shaft and valvebody differences).
