shift lever ques.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wickedk5, May 25, 2000.
  1. wickedk5
    wickedk5 Registered Member
    May 3, 2000
    30
    Ca.
    i have a '90 blazer with an a/t and my shift lever feels loose and wiggles back and forth easily when i pull it back to shift gears, is there a cable or something that i can just tighten so that i can get the tension back?
    thanks
    "And if it ain't a Chevy don't raise it up..."
  2. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    If I understand you correctly you are talking about the rod that goes down from your steering-coulumn (by the firewall, engineside) to the a/t-shifter. Mine feels a litle "crisper" after I lengthened it when I did the bodylift. Maybe you should crawl under her and have a feel that everything is nice and thight in both ends, and nothing is comming loose.
    [​IMG]<font color=blue>Espen88k5</font color=blue>
