shift rod differences?
Discussion in 'The Garage' started by colbystephens, May 7, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    i'm curious if the thread on the gm shift rods are all the same. i've got one of roadnotca's sweet shifter knobs and i'm switching from a 700/208 combo to a 465/205 combo and want to know if the knob will swap over to either of these shift rods. thanks.
  2. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    with some JB weld, any thing will stick.
  3. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
  4. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i don't know - i've had lots of problems w/ jb weld. any other thoughts?
  5. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I'm thinking you should tune up your JB Weld skills. A very essential skill to have. :wink1:
    Just get a perfect 50/50 mix, stir it up well, slap it together, and DON'T touch it for at least a day. If you go past the working time, or screw with it when it's not cured, then it won't go well.
  6. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    yeah, i know how to use the jb, just isn't strong enough for me. the d@mn locksmith tried to jb weld my tailgate handle back together after he broke it, and it lasted a couple days. then i had to replace the tailgate handle, swap the lock cylinder which i paid way too much for into that handle and install the handle. i spent way too freaking much to realize that in one hour i could do the same job they did in three and a half hours.
  7. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    well we arent talking about a moving part here. just a shift knob. it stays stationary to the shift rod, therefore doesnt see a whole lot of stress.
  8. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    you're right. the shift rods are never moved - they're entirely stationary. no one ever uses shift rods on this board - we are just mall crawlers and add 465 or triple stick shift rods for the looks - we never touch them tho. :wink1:
    so no one has a straight up answer?
  9. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    you know what i meant. have you gotten the old knob off yet? just try it and tell us if it works.
  10. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i won't have my new gear boxes till the end of july, and i want to know if my current knob will fit. otherwise, i would have just tried it. ;) it would have cut a lot of bs that way. :D
  11. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I just pulled the shifter knobs off, the 465 shifter is 3/8" x 24 TPI (UNC), the 205 shifter is 7/16" x 18 TPI (UNC)
    Hope that helps...
    Rene
  12. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    that's great, thanks!
  13. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    And I *think* that the 203 knob that I used to have was the same as my 205 knobs, though that has nothing to do with your application. Sorry. :dunno:
  14. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    that's cool - maybe it will help someone else out. any one know what the thread is on a 208 shift rod? i could perhaps check mine, but my truck is about 30 min away and i don't have the proper equipment.
  15. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Alright, I just went out in the dark and checked the shifter on an 85 K5 with a 208. Looks like 7/16-14 threads. Don't think it'll work for you.
  16. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Are you sure it was 18 TPI? Oh and UNC stands for "Unified National Coarse". 7/16 UNC is 14 TPI, 7/16 UNF is 20 TPI. 3/8-24 is a UNF thread. 7/16-18 would be pretty nonstandard, and not UNC or UNF. I'd go measure my 205 shifter, but my stupid tap and die set came with 2 metric thread guages instead of one of each. :mad: That's always annoying.
    Either way, I can assure you that the 205 is not coarse like the 208 is.
  17. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    LOL, I was having a retard moment. Had a neighbor come over while I was posting and I got a bit distracted. UNF for both, and 20 tpi on the 7/16" sounds right. I was gonna double check before posting...sorry for any confusion. :doah:
    Just to be more clear the 465 thread is 3/8" fine thread and the 205 is 7/16" fine thread.
    Rene
  18. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Ok, cool. Just wanted to check. I wouldn't put it past GM to use something odd like 7/16-18 anyway. I've seen stranger things.:rolleyes: Probably just 7/16-20 though.
    So Colby, what is this shift knob you speak of made out of anyway? I'm sure there's a way to make it compatible with your new shifter. Either drill it out and install a threaded insert of some sort, or try forcing it on even with the wrong thread pitch, or weld a nut (aluminum or steel if you have a metal shift knob) to the bottom of it that's the right size, etc. I would just drill out the hole in the knob to 7/16, pack it with JB weld, and slip it in. The major diameter of the threads on the 205 shifter will be 7/16, so it will fit snugly in a 7/16" hole. The minor diameter of the threads will pack up with the excess epoxy, and give it a better grip. If done properly with clean surfaces, I assure you, the knob WILL NOT come off. That's with REAL JB weld though, don't mess with that JB Kwik stuff.
  19. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
  20. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Well then, not too easy to weld to I suppose.:crazy: Not easy to ream out with a drill bit either, plastic likes to chunk out when you're stepping up drill bit sizes. Especially the #2 ball...don't ask me how I know. You could just try ramming it onto the different threads though. It may work, might not.
