Shift to 4wd, while driving
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Alaskan85K5, Oct 16, 2001.
  1. Alaskan85K5
    Alaskan85K5 Registered Member
    Sep 5, 2001
    32
    Anchorage, AK
    Got a question for all you experts. I have an 85 Blazer when I want to use 4wd I have to shift into Neutral then put it in 4x4. Is there a way to change this so I can put it in 4wd while in Drive (preferable while moving). (This is all assuming that the hubs are locked in already).
    Also why would my lights (left on) buzzer stop working? Is there a fuze or something?
    Check out my K5 <a href="http://www.jeremias.net/photoalbum/?path=The%20Family%2FJasons%20K5%20Blazer"> Here! </a>
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    you should be able to shif into 4hi when driving but not 4low i have the np205 and am able to shift from 2hi to 4hi up to like 30mph (never tried anything above that)
    wheeling videoshttp://community.webshots.com/user/ssmith6333
  3. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    you should be able to go from 2hi to 4hi while moving, as long as you're under 15-20mph. To go to 4lo, you will have to stop and put it in neutral, or park.
    As far as the buzzer, it's just a small little box that makes noise. It is probably gone bad and needs to be replaced. Sorry I don't have more info for ya, I just rip those things out anyway --- they drive me crazy!
    Thomas.
    -- '84 1-Ton Blazer --
    When the goin' gets tough,
    the tough go 1-Ton [​IMG]
  4. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Yeah, what they said. However, I like to engage when in neutral. just seems more safe or less ware and tare.
    Surgeon General's Warning:
    Viagra and steroids may be harmful to your spouse![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  5. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Ditto to the others. 4HI you can do while moving. While on the trail, I leave my hubs locked and shift in and out of 4HI all the time. I only use 4 wheel drive when I need it. To get into 4lo, you must be in neutral. I wouldn't shift into 4HI at much speed, however. You are just asking for something to break when everything grabs.
    Just my .02
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
