Shifter moving
Discussion in 'The Garage' started by dendeanda, Oct 3, 2005.
  1. dendeanda
    dendeanda Registered Member
    Apr 21, 2005
    46
    Corpus Christi, TX
    When I go wheeling it gets pretty bumpy. When I am in 4H and I hit a pretty good bump, my shifter automatically moves to 2H. What should I do? Any help would be appreciated!
    85 Blazer 5.7L Auto
  2. darenofears
    darenofears Registered Member
    Jan 25, 2005
    47
    Indiana
    use a 2x4 to hold it in place
  3. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    ratchet strap it. i used to do it on my 208 when it did that.
    I think it has something to do with the mount of the transfercase, whether you lowered it or not, etc. it's a common problem i think.
  4. logan 84
    logan 84 Newbie
    Oct 4, 2005
    Olympia WA
    I have an 84 that has done that to me and I used a bunge cord to hold it in place.
  5. dremu
    Feb 27, 2000
    15,970
    462
    East of San Francisco
    You may find that adjusting your t-case level helps. You may also find that your t-case, tranny or engine mounts are needing replacement.
    I think you have an NP208 and I've no idea how them newfangled things operate.
    Or you could bungee it (I did 2000 miles once with this, to keep mine from rattling). Bungee or ratchet strap is cheap and doesn't require getting under the truck :D
    -- A
  6. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    take the cover off of the shifter and grind down the shifter rail a little bit. mine did the same thing and realized that 4hi did not engage all the way. i had to grind about 1/4" so the shifter could move back a little more...it is on a 208...i have not had any problems with it since.
