Shifter wiring
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sickquad, Jan 19, 2004.
  1. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    So, I'm installing a B&M floor shifter. It was ment for a camaro and I got it for free but it fits nice in the console I just made.
    My question has to do with the wiring. There are two switches on the shifter, one for reverse lights and the other for the neutral/park lockout. Anybody wired up one of these before?
    I have no directions and I lent out my service manual and now it is mysteriously missing. Any help would be appreciated, haven't found anything yet on a search of the board.
    -Chris
  2. gotmud77
    gotmud77 1/2 ton status
    Aug 4, 2003
    689
    bellefonte
    i have mine tore apart at home if you can wait till later i will post back with the answer. it will be after 8pm
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I just hooked up the missing reverse and p/n switches in my newly acquired 88 which had a B&M ratchet. Big question is, what model do you have?
    For me, the switches are on the lower part of the column, and I just extended the leads to the new shifter switches. P/N is orange and black on a single plug at the very base of the column (next to the fire wall). Reverse is (IIRC) a blue and a green wire on a common plug right beside the p/n (common switch). Nothing tough, just hook those wires onto the new switch. Technically, I don't think you need the black from the p/n as you could just go to ground at the shifter.
  4. sickquad
    Jul 23, 2003
    785
    Ma
    Sounds good, thanks for the info. Are the wiring colors the same for all trucks? Mine is an 85 with 84 wiring and a 87 steering column. I guess I'll find out.
    -Chris
