Shifting Hard Into 2nd
Discussion in 'The Garage' started by buffcc1, Nov 10, 2006.
  1. buffcc1
    buffcc1 Registered Member
    May 30, 2005
    42
    Wichita Falls Texas
    I have a 700R4 and its shifting hard into 2nd gear any suggestions?
  2. Bigdawg234
    Bigdawg234 Registered Member
    Apr 11, 2006
    29
    Leechburg, PA
    Mine was good for that, it took a few seconds to shift then slammed into gear.I'm not sure what the cause excatly is, but a towing shift kit from tci seemed to make mine just right. It doesn't shift hard like race kits due, but still shidts quick. I did a full rebuild cause i lost overdrive and third, but if yours isn't slipping then that shouldn't be needed.
  3. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    Is it hesitating to shift into OD as well? My throttle valve cable had slipped through the little adjuster on the side of the throttle body and it threw off the 2nd and OD shift points. Check the shop manual on adjusting.
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I can make mine shift ****ing hard into second. If I am WOT then I backoff right before the shift it slams really hard. I am a believer that a hard shift is better than a lazy shift that lets the bands slip.
    Ira
  5. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    1. Fluid Level
    2. Modulator vacuum hose (look for vacuum leaks, cracks, etc
    3. Modulator
    These are things that I have had problems with.
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    wrong trans, 700's don't use vacuum:p:
    either the cable has changed position, or get ready for this,,,,,the trans is on it's way out..
    My first one started out this way, then eventually it wouldn't shift out of 2nd at all,,,now my second one is starting this same thing, gradually getting worse every day...
    really sucks:(
  7. gmcjimmy4x4
    gmcjimmy4x4 1/2 ton status
    May 6, 2005
    132
    Sacramento, CA
    when i first bought my jimmy, they told me it had a shift kit. Boy did it shift firmly into second. A month later it shifted into second for the last time.(luckily i bought the extended warranty) The dealer told me that it was totally thrashed with huge chunks of metal laying in the bottom, of the pan when they inspected it. Hope this isnt getting ready to happen to you too!:doah:
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Mine has ( knocks on wood ) shifted hard into second since I boight it almost 100,000 miles ago . Mine was rebuilt by the p/o . It has gotten better , but it was each change of gearing . The less I have to get into the motor , the less the cable is pulled , the easier the shift .
