Shifting Tcase
Discussion in 'The Garage' started by CHEVY 4WD, Jan 20, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    would it hurt anything to shift from 4L into 4H if you were racing on the street(in like a Jeep or similar)? I sal a guy shift from 2wd to 4wd at the sled pull make me wonder it dident grind or anything and he dident let of the gas.
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Yes. 4LO to 4HI shifting while moving is the leading cause of planetary t-case failure.
    One you have a NP208 or NP241 apart, it becomes very obvious why this is so. There is a collar that engages a ring with some very small teeth on it. There is no synchro rings that I'm aware of... just the teeth are pointed to aid in the two sliding together. These small teeth become shredded on hi/lo shifts while driving.
  3. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    I dident think it would be a good idea but just wondering
    what if you hit neutral then shifted to hi then back in drive? BTW 2hi into 4hi dosent hurt anything?
  4. u2slow
    May 9, 2001
    2,217
    BC Canada
    Shifting to neutral won't make any difference. You're still trying to mesh a faster moving part with a slower moving part, one turning 2.7 times faster than the other.
    The input side of the t-case won't begin to spin down until the t-case is in neutral. Even then, you'll be shifting a collar (moving according to the speed of the rolling truck) to mesh with a now stationary input side.
    2wd to 4hi and 4hi to 2wd is okay since the front output and driveshaft are already turning at the same speed of the truck. The t-case uses a synchro to enagage the front output drive so that its brought up to speed as its shifted (basically, lets you use auto-hubs).
  5. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    On my 208, I can't go from 4hi to 4lo without having the tranny in neutral first. And from my racing days, I don't see the point of this in the first place. I can't think of many instances where you would be in 4lo on the street. And especially not while racing. And if you're on the street, why use 4wd anyway? You probably don't need the added traction as much as you need the engine power.
  6. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    well it would have been with the hubs unlocked and some 4 bangers are kinnda slow and if you could use a lower gear it would come out of the hole faster. its not for a blazer
  7. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    toyota made a T-case that could be shifted into 4LO on the fly, why i dont know but they did. and remember when you shift into 4 lo and you hear it grind, thats just metal leaving /forums/images/graemlins/blush.gif.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
