shifting
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JayG, May 26, 2000.
  1. JayG
    JayG Registered Member
    May 23, 2000
    8
    erie, pa
    i have an 86 k-5, its an automatic and when it shifts from 1st to 2nd gear it jerks the whole truck real bad what could be causing this?
  2. J.R.
    J.R. Guest
    it can be any one of a number of things,i would start with the tranny fluid and filter change.when your truck is good and warmed up,check the fluid,not just to see if its low but the color,and the smell off trans fluid can tell you alot,if the color is dark like blood and it smells burnt,then you may have real problems.i would start with the fluid,if that doesnt help take it to a trans shop for a free inspection,let them figure it out and then you take it home and fix it.good luck!!
    BIGBLOCK MAN
  3. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    <font color=blue>http://www.thegrid.net/thedrivetrainpage/<font color=black>
    go to this site, it will explain the clunk and what to do...
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
