Shim Degree for front axle
Discussion in 'The Garage' started by 1HighK5, Oct 7, 2005.
  1. 1HighK5
    1HighK5 1/2 ton status
    Feb 7, 2005
    140
    New York
    In a few days I will be ready to put the front axle in my truck. I am going to need to shim the front leaf springs to lessen the pinion angle. I am not sure how much lift I will have when I'm done I have 10 inch springs and am using ORDs extended shackles so it should be around 11 inches or so when its all done. Any way how big of a shim can I use on the front axle before it messes with the steering? Any info will be appreciated Thanks John
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Well, the first question is how much of a degree change will the springs give? Then you have to ask what constitutes "messing with the steering". Adding those shackles is going to give you a couple of degrees in the wrong direction. 10" springs are so high that you may be forced to rotate the knuckles to have both proper pinion angle and proper caster. If you don't want to do that, you'll have to figure out what compromise between the two you like the best.
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i have 8" springs and have 5degree shims on and it works out fine. not sure how 10" spring are gonna be. it would help alot if u got zero-rates to move the axle forward 1-1.5".
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Is this going to be driven daily or what? You going to loose all your caster. The proper thing to do with that much lift would be to have the knuckles cut and turned.
