Shim Question with Echobit shackel flip
Discussion in 'The Garage' started by TXsizeK5, Dec 5, 2002.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Who is running a Shackel flip from EchoBit?
    What degree shims do you need to get the angles right?
    I am thinking of getting a set of those shcakel flips, and getting those tappered bolt on leaves from A-tron. Can you recomend a good angle for the shackel flip and stock springs? Thanks!
  2. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    TTT, anyone know? Whats the basic degree you would need for a 6" lift with the tcase already droped? Thanks.
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    You'd be best to measure it. Sears sells a decent angle finder/protractor thing for $12.
    With the tcase dropped already, I'd guess 4 degree - key word is guess.
    -- Mike
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    There are too many variables. Driveline length, how much the T-case is dropped, perch location on the axle itself etc etc. Shim size and driveline angle is one of those things that needs to be figured out on a truck by truck basis, measured and then corrected.
    You'll need to do the flip and see how much you need...then get the angled leaf block from A-tron when you know how much you need on your truck.
    Rene
  5. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    Yeah, I asked my mechanic friend ASE master certified /forums/images/graemlins/grin.gif
    And he said, the best he can guess is 4 to 5 degrees for a 5-6 inch lift. How many degrees can it be off before it starts vibrating and showing bad driving characterisitics??
  6. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    THIS MAY BE DUMB BUT WHAT IS THE ANGLE SUPPOSED TO BE? THANKS
    NATHAN
  7. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> With a CV the pinion should be pointed about 2-3 degrees down from being straight in line with the d-shaft, with u-joints on both ends of the shaft the pinion and output shaft on the t-case should be parallel. </font color>
  8. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    THANKS
  9. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    If you get the A-tron shims, make sure to figure out first if you need the axle back 1" or 1.5" since they will need to know which side to mill.
    -- Mike
  10. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    You can also have it at 0" which I plan to do.
