Shim the pinion angle or drop the trans case?
Discussion in 'The Garage' started by Stickseler, May 15, 2003.
  1. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Ive got a slight vibration since my lift and I've been told my drive shaft angle is off by 3 or 4 degrees.
    Would I be better off Shimming the Spring perch or Dropping the trans case?
    I've got zero rates now but I could replace them with the A-tron ones.
    What are the drawbacks to either?
    My U-bolts lean forewords a few degrees if that matters or is that normal?
