Shim Width question
Discussion in 'The Garage' started by MilpitasK5, Sep 12, 2003.
  1. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    Can I use a 2" wide shim for my rear leaf springs? I think they're 2.5".
    Will that be unsafe or does anyone have input?
    86K5 going install the Echobit Shackle flip tomorrow /forums/images/graemlins/smile.gif
    TIA
    Chris
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I would stick with a full 2.5" width shim, especially if your spring perches are not completely flat but have holes on top. If I had to use 2" shims they should only be steel! Getting ready for the transformation, eh!
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Ok Chris. I found the shims and they are 2 1/2" wide aluminum 6 degree.
