shiming after shackle flip
Discussion in 'OffRoad Design' started by Tice, Sep 9, 2002.
  1. Tice
    Tice Registered Member
    Aug 24, 2002
    36
    southeastern arizona
    just installed 4in shackle flip from ORD. now my u-joint angles are off. have 1in drop t-case brackets. how much of an angled shim do i use to correct it? front u-joint sits at 9 degrees and rear is about 1 degree.
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You should match the ujoint angles front and rear. They need to match so you'll probably want to look into about a 6 degree shim? We've messed with a couple blazers that just used 4-5 degree, so you might get away with that.
    Best way to do it is figure out what you want and cut and rotate the spring perches.
  3. Tice
    Aug 24, 2002
    36
    thanks, i'll try that and let you know how it works.
  4. Tice
    Aug 24, 2002
    36
    thanks. that whorked great. i used 6degree shims and got the angles to within 1 degree of each other. also i found shims that didnt have a pre drilled hole , so i was able to drill my own holes and bolt them to the spring packs. ps ORD RULES...
