shimming for home ade shackle flip?
Discussion in 'The Garage' started by Jonny-K5, Jul 19, 2003.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    im in the middle of my shackle flip and im wondering if i need shims . im doing the cut thru the stock hanger thing. anyone know? ill be putting it all back together in the morning.
  2. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    after your flip see where the truck sets (after it has taken a "set" on the suspension. Then measure your pinion angles... do a search there are numerous posts about pinion angle and how to fix it... my truck was already setup to have the perches welded... so all I have to do is get the optimum angle.
    www.Jeepwire_Com Presents Setting Your Pinion Angle
    hope this helps
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    The shackle flip will angle your axle up for you. I say put it together and see how close it is. My shackle flip and flat 2" block worked out about perfect on the angle.
