Shimming rear penion after shackel flip...???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BozoWise, Jul 1, 2002.
  1. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    I have removed my blocks and added a shackel flip. Now my 14 bolt is straight inline with the driveline. I drove it back to my shop and got a bit of vibe from the rear now at about 35 and it was getting worse with speed. I dropped the case 1" with the factory spacers and haven't had time to drive it yet. But my question is what is the optimum angle for the rear pinion. I thing it should be parralel with the trans output but not sure. What is the best way to figure the degree shim needed? I know it is trial and error, but I would like to get close on the first try ;-) Thanks guys.
    P.S. Got new pics up on the webshot page that show the shackel flip install and the new driveline angle in reference to the shaft and pinion.
  2. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    i always seem to here "4 deg." with a 4" lift IMLAO /forums/images/icons/grin.gif
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I've found that about 2 degrees below parallel with the t-case gets rid of the vibe, which is about where your driveline was before the flip. You should need no more than a 6 degree shim to correct it, 4 degrees might be the ticket but might not get the pinion that extra 2 degrees down to compensate for spring wrap. Where you running tapered blocks before the flip or square blocks? Looks good!.
    Beater74, you sig is killing me!
  4. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Square with the factory springs and 12 bolt... same when I swapped out the 12 for a 14. No vibe with either setup.
  5. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I'd say your definately between a 4 and 6 degree shim. I purchased a set recently for 11 bucks, so they are not too expensive.
  6. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Ok I'm taking votes now from everyone....
    4 0r 6 degree ;-) dumm dumm dummm what is it going to be
  7. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Who carries the shims?
  8. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    BW if the pinion is pointing at the TC then that's what you want if running a CV joint at the TC end. So it's trying to tell you to get a 1350 CV driveshaft. /forums/images/icons/shocked.gif /forums/images/icons/ooo.gif /forums/images/icons/cool.gif /forums/images/icons/grin.gif /forums/images/icons/tongue.gif /forums/images/icons/wink.gif /forums/images/icons/smirk.gif /forums/images/icons/laugh.gif /forums/images/icons/smile.gif /forums/images/icons/blush.gif
  9. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I know you can get them from ORD...
    My pinion looks like its pointing pretty high too... even with the 1.5" offset Zero Rates. Hope the vibes aren't too bad! /forums/images/icons/smile.gif /forums/images/icons/tongue.gif
    -Dan
  10. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
  11. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    mt driveline on my 14ff is pointing right at the xfer case.. i get no vibes...
  12. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    I sure wish I had the money for CV shaft, but not at the moment.
