Shimming the PS pump?
Discussion in 'The Garage' started by dremu, May 17, 2006.
  1. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    As part of my hydroboost install I have changed the reservoir, and when I took the pump off I discovered that the bracket was busted, so I did a little welding and what I *thought* was straightening :doah: and ...well, short story, the pump is off kilter, methinks, and whines like a sumb!tch even at idle when bled. :(
    I can see how it's tweaked by the old "visual inspection", so it's bad. However, the local Pick-N-Pull had no brackets like mine ('74 big block) and I fear going to the dealer ... so, I think I've screwed the pooch.
    I am thinking that I might be able to get the pulley back in line with the water pump, etc by putting a washer behind the bracket ... is this a really, really bad idea, and I should beg y'all to send me a replacement bracket ... or is it doable, d'ya think?
    -- A
  2. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    perfectly o.k. I have used washers/ shims many times.
  3. theperfectgarage
    Oct 5, 2005
    988
    tucson arizona
    No prob at all. I have made spacers many times to get belt alignment correct.
    EDIT- I am so BUSY AT WORK, I answer posts twice.:laugh: Least I don't PAD.
  4. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    No problem at all. My motor has quite a few 1/2" nuts on it for accessory bracket spacers.
