Shimming
Discussion in 'The Garage' started by yellowmoon, Oct 18, 2002.
  1. yellowmoon
    yellowmoon Registered Member
    Dec 30, 2001
    94
    Modesto Ca.
    Went to shim my rear axel to get rid of the vibration, and the darn shackle bolt is too short! What gives? Am I going to be able to find longer bolts?
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Shakel bolt? Do you mean Ubolt? If so you can get new bolts from California Off Road right there off Kansas by Hwy99 or Kyle Off Road off Yosemite.
    Good Luck /forums/images/graemlins/thumb.gif
  3. yellowmoon
    Dec 30, 2001
    94
    Modesto Ca.
    Actully it's the spring center bolt. To go thru the shim there isn't enough to go into the hole in the block. Tried a washer (what California four wheel said). Thinking about rewelding the bracket on the axel.
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You can get those at NAPA.
