shimmy above 60mph
Discussion in 'The Garage' started by hunterguy86, Dec 4, 2005.
  1. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I have an 86 k5. Everything is stock. When I go above 55-60 mph everything shakes. I've looked at the tires and they look good. I just bought them in march.
    All the wheel weights are still in place as well. What should I be checking for. Its really annoying when drivin on the highway.
    By the way I'm runnin 31x10.50x15 kelly AT's
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Check the u-joints
  3. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    I know I start to get a shimmy when the steering stabilizer is going bad. Might be worth checking.
    Could be alignment also.
  4. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Could this possibly be it? I do notice a bit of a whine when I left off the gas. Maybe the 2 are related. What should I look for when checkin the ujoints
  5. readymix
    May 30, 2004
    6,706
    26
    Check to see if there is any slop in the joint, Also verify that there is grease in them.
  6. guido666
    Feb 16, 2005
    788
    Longmont, CO
    See if they are obviously broken or mangled. Then see if there is any slop in them (put the transfer case in gear, lock the hubs, jack up the front axle, and wiggle the tire forward and back and see if there is slop between the two halves of the shaft).
  7. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I'm pretty sure the alignment is good. It dont pull in any direction so that should be ok
  8. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    mine does this also but only between 60-74 and at 75 it completely stops and i can cruize at that speed fine, untill i see a CHP.
  9. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Alignment will never cause a vibration. Put the truck in neutral and see if the shaking stops.
  10. guido666
    Feb 16, 2005
    788
    Longmont, CO
    It will if you get it so out of alignment that there is a toe in/out condition. Remember my thread about that you replied to? It would hop when moving slow, then it was unnoticable until you hit about 45 and then the harmonics were just right. I fixed the toe-in and it didn't do it anymore (it was the only thing I changed).
  11. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Yes, I did not take into account a tire that was visibly pointing in a different direction than the other.
  12. guido666
    Feb 16, 2005
    788
    Longmont, CO
    I wasn't trying to be rude, and my tires were nowhere near VISIBLY toed in. They were off by about 1/4-5/16" together in the front vs. the rear of the tires' measurment. It didn't take a lot to make a huge difference. That's why I suggested it.
    Oh, I sent your console by the way. :D
