shimmy at 45-50?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kombi59, Oct 18, 2003.
  1. kombi59
    kombi59 1/2 ton status
    Nov 15, 2002
    197
    hi guys new here, i have an 84 k5 with a 350, t350 trans, 6" lift 35x12.50 bfg muds. rides nice but around 45-50 i get a slight shimmy. i have already shimmed the transfer case. any other suggestions? ay appreciated thanks chad.
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Sounds like the typical "u-joints need replacing on the rear shaft."
    Does it get worse the faster you go, or does it stop after 50? If it gets progressively worse I would say wheels out of balance.
    Oh, and welcome. Thanks for supporting the site. /forums/images/graemlins/thumb.gif The addiction will soon kick in. /forums/images/graemlins/cool.gif /forums/images/graemlins/smirk.gif
  3. kombi59
    Nov 15, 2002
    197
    brand new u joints front and rear, brand new tires and just balanced? stops at faster than 50 and lower than 45? only for about 2-3 mph in between 45-50? other than that rides real nice
  4. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Could be a balance problem in the tires.my old 42" swampers would shake like hell but at 55 to about 63 it would ride fairly smooth. Also did you check your front end?Ball joints,Tie rod ends............
  5. kombi59
    Nov 15, 2002
    197
    the alignment is a little off would this do that though? thanks off to the alignment shop monday went to 35's from 33's and it is a little worse. thanks all.
  6. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    if you can drive out of it go have the tires re balanced...
    azblazer
