Shimmy Shack Tunk CLunk
Discussion in 'The Garage' started by speed4life, Sep 28, 2006.
  1. speed4life
    speed4life Registered Member
    Sep 24, 2006
    7
    Roanoke Virginia
    Ok oK guys I am new to 4wheelling and trail riding I bought my 88 K5 about 2.5 months ago has been a dream of a vehicle CLEAN CLEAN.
    Now here is the deal I have taken it on some trail rides (nothing extreme) just that trails (dirt roads and the normal pot hole)
    Went sunday and got a little muddy (no biggy) Been driving it all week to and from work ----- this morning driving to work my truck start making WIERD noises and the dam brakes felt like they were sticking irraticaly. Dont know how to explain it other than that i am getting a thunk noise from the rear and what fells like a bumping fell at the same time
    It DOES NOT sound like metal to metal (none of the usual sounds that meatal would make
    It has done this around 30mph and also on the highway at like 65mph
    I have never used the 4wheel drive yet but to test it before i bought it and thats it - So I can say its not the front wheel drive section ot anything
    What I like to find out is it posible that the brakes get clogged up from dirt and crap
    Any ideas would be greatly needed if anyone else might have been through this
    thanks from
    Randall
    Roanoke Va.......
  2. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    My truck makes a lot of weird noises. You know what I do?
    Turn up the radio! :D :D
  3. speed4life
    Sep 24, 2006
    7
    Roanoke Virginia
    Oh need to add the bump noise or feel isnt just the rear its like throught the hole truck ---- Really wierd
  4. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    I installed boggers!
  5. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    maybe your e-brake, my cousin took his f@rd wheeling in the sand one time and he told me his felt like that and i checked all over and found out he had the e-brake on!!! figures typical f@rd drivers!!!LOL
  6. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    yes you can get mud in the drums. that can cause problems with braking. you should be able to jack it up, pull the wheel and pull the drum. clean the snot out of it.
  7. speed4life
    Sep 24, 2006
    7
    Roanoke Virginia
    I took it to a car wash this evening and sprayed the hole under carrage not sure if it will help but I like my truck and turning up the radio or putting noisy tires on is out of the question
    I did howevercheck the e-brake and it works fine the brake pedal does however feel sticky at times and with no consitincey at all it to statred this morning with everthing else....
    HHHHHEEEEELLLLPPPP
  8. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    does it feel like your pulling some thing heavy?? might be the brakes like chas said
  9. 88-3/4t-bad boy
    88-3/4t-bad boy 1/2 ton status
    Nov 27, 2005
    150
    Texas
    yeah. drum brakes can be notorious for crap like that. my sub felt that way for a while when i drove on the road after mudding. id check the drums like chas said. Or you could do what im planning on doing later and convert them to disk. They are alot smoother and not to mention alot easier to work on. But if it feels like the brakes then i would do a full underbody inspection, check all your lines, check or change your fluid, and if you still cant find out what it is then clean the drums, but thats just my $.02.
  10. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    Mud caked on the inside of your rims might be what you're feeling.
  11. Brians89K5
    Brians89K5 1/2 ton status
    Jan 4, 2006
    535
    Rialto Ca.
    my blazer clunks and rattles and shakes and shimmies too. Must be a k5 thing? I vote for mud in the rotors too!
    ~Brian
  12. speed4life
    Sep 24, 2006
    7
    Roanoke Virginia
    Well guys I like to say thanks to you all it was the drums and BOY were they full of crap i took off the drum and the smell that came out of it stunk to high heaven. They were pretty dirty and nasty the cables are fine but i still re-lubed them and cleaned everything
    Thanks for everyones help in it
    So does anyone here live near Roanoke Va -- we got some great trails in the area along with some good home cookin
    If anyone plans on driving this way just hit me up I'll Host and be a "tour guide" lol
    Later guys
  13. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Its mud in the drums.
    EDIT- I saw you already figured it out. Thats one of the reasons I dont go "mudding." For one it gets boring after a while, it messes up your brakes, it kills u-joint, kills wheel cylinders, eats wheel bearings, and causes rust. Rocks can do some serious damage too, but if your drive careful its not that bad.
    -Harrison
  14. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    I would like to know exactly just how mud does all this damage. could it be you don't grease anything under your rig and then water gets in.
    the rust is because you don't clean your truck afterwards. you could say all the same things about road salt.
    Mud never gets boring. I can pull jeeps out all day with a smile.
  15. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    yup i like mud and down here there is no rust only from people not washing the mud off
  16. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    lets here from some more sane people like chevy wrangler
  17. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Well if wasn't for mud I think CK5 membership would be a tad lower. For most of us the trails are either mud or snow, with the exception of maybe two weeks in the driest of August's!
  18. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    I might be drunk right now but your sig line is hilarious.:haha:
  19. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Hopefully both! :D
  20. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    Mud is a blast,rust has never been an issue,and as said keep it all greased,no problems.Might be a pain to wash,but hey!
