shimmy shimmy shimmy...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, Feb 21, 2002.
  1. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    that's what my suburban does when i slow down, along with the normal right pull. could my rotors be damamged? please tell me they're ok and i just need to get the truck aligned. but it's not a fast shimmy, it's a slow one.
    --Scott, 1989 GMC Suburban 2500 4" lift, 36" TSLs
    <a target="_blank" href=http://community.webshots.com/user/muddysub>http://community.webshots.com/user/muddysub</a>
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Check both!
    Warped rotors can wear out your front end and then you will need an alignment also.
    Warped rotors feel more like a shudder to me. Shimmy or death wobble you should feel alot of movement in the steering wheel.
    Dave
    Rehab is for quitters.
    <a target="_blank" href=http://coloradok5.com/gallery/Daves-Pics>http://coloradok5.com/gallery/Daves-Pics</a>
  3. DUKE
    DUKE 1/2 ton status
    Nov 14, 2001
    879
    Davenport Iowa
    my brake pads did that just before they went out.
    DUKE
    Why go around when you can go over?
    <a target="_blank" href=http://student.fortlewis.edu/~rdgebhardt/>http://student.fortlewis.edu/~rdgebhardt/</a>
    85 K5 <font color=blue>Big Blue</font color=blue>
  4. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Also check the slider pins on your calipers any imperfections or blemishes can keep the calipers from adjusting on the rotors properly...maye pull the pins and check them out
    Definately a pavement pounder...with the caveman clutch
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
  5. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    If your rotors are warped you should feel it in your brake pedal when you slow down. It's pretty easy and cheap to get them turned if that's the problem. Ya might wanna check those big ol' tires too.
    Michael[​IMG]
    <a target="_blank" href=http://www.jmartin.net/goose>www.jmartin.net/goose</a>
  6. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Check to see if you have broken a belt on one of your tires. My back wobbled alittle and thats what that problem was, good excuse too buy new tires.[​IMG]
    <font color=blue> I'd rather have a bottle in front of me, than a frontal lobotomy!
