Shims and Zero-Rates
Discussion in 'OffRoad Design' started by bluehen, Mar 20, 2006.
  1. bluehen
    bluehen 1/2 ton status
    Nov 11, 2004
    215
    DE
    If I need to shim the rear axle and intend to install zero-rates, should the shim go on the top or bottom side of the zero-rate? My initial thought would be to treat the zero rate as a helper spring, and set the shim beneath it. But not sure how that would work if I need to use the offset. Help a Newbie out....
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Zero rate bolts to the spring pack. Shim must go below.
  3. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    I think they will cut angles into the zero rate for you.
  4. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I agree:D
  5. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,068
    194
    Colorado
    Give a call you can get the Zero rates milled to act as a shim as well as the extra lift.
  6. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Placed my shim under the zero rate.
