shims in front
Discussion in 'The Garage' started by DERBINATOR, Mar 31, 2005.
  1. DERBINATOR
    DERBINATOR 1/2 ton status
    Jan 26, 2001
    196
    YANKTON,SD
    At what point is a degree shim or offset shim considered a lift block?
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    I read somewhere(a long time ago) that you shouldn't go much more that 3 degree on a front shim.. *shrug* And if you can, get machined steel shims rather than the ones made by most aftermarket companies which are some sort of cast.
