Shims with 52's + Zero Rates
Discussion in 'The Garage' started by trollporter, Oct 27, 2006.
  1. trollporter
    trollporter 1/2 ton status
    Feb 29, 2004
    518
    Lady's Island, SC
    I searched but couldn't quite find what I was looking for. I plan on running stock 52's up front with overloads and zero rate moving the axle up 1.5". What shims are you running or suggest with this set up.
    thanks, troy
  2. trollporter
    Feb 29, 2004
    518
    Lady's Island, SC
    Surely I'm not the only one to ever try this in the history of ck5.
    troy
  3. 89Burben
    89Burben Registered Member
    Jan 3, 2005
    98
    CT
    i was going to do this when i put my zero rates in my front of my truck. instead of using a shim then the zero rate, i was thinking about having a machine shop mill a certain degree into the zero rate for strength...hope this helps
  4. trollporter
    Feb 29, 2004
    518
    Lady's Island, SC
    great idea man!
    troy
  5. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Are you sure you'll have enough clearance for the draglink over the spring packs? I'm running 56s minus 2 leaves and the overload. Room was somewhat tight. Just something to think about.
  6. 89Burben
    Jan 3, 2005
    98
    CT
    this is why i didnt pursue the idea because the more of an angle you put on it the more it rotates your draglink & tierod into the front of your spring. You just would have to look at it and try to picture it and/or try it.
    i just didnt do it b/c i had just bought new u-bolts and im lazy:D
