Shiny new axle...
Discussion in 'The Garage' started by goldwing2000, Nov 19, 2006.
  1. goldwing2000
    goldwing2000 Guest
    So I finally got some pictures of my freshly-built front axle.
    Here's the before pic:
    And here's after:
    Mmmmm... powder-coated lusciousness. :D
  2. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Nice!
    Are you gonna go crossover in the future?
  3. goldwing2000
    goldwing2000 Guest
    Probably not. I'm not a hard-core wheeler but I AM a cheap bastard. :D
    I use it more for towing than for wheeling. I already have a raised steering arm but if anything, I'll get a drop pitman arm and call it a day.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Did you powdercoat the surface of the knuckle & bottom of the steering arm where they meet? If you did you might want to pull the steering arm off and polish them back to bare metal.
    That surface is ment to have a direct metal to metal contact patch to promote friction. If you paint or powder coat them the arm can slip & break the steering arm studs off. This may not be as much of a problem since you don't have crossover but I am not 100% sure if it is bad or ok. I know in crossover it is a big no no.
    Looks good by the way though.
    Harley
  5. ChickenRammit
    ChickenRammit 1/2 ton status GMOTM Winner
    Aug 21, 2005
    3,186
    FONTUCKY, CA
    how did you remove all the rust and uglyness
  6. gmcburb1965
    gmcburb1965 clever user title
    Oct 29, 2005
    61
    Colorado Springs
    Cheap and powder caot don't usually go together :)
  7. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    Sure is purdy though! :waytogo:
  8. goldwing2000
    goldwing2000 Guest
    Hossbaby: Nope... steering connection is clean metal with lots of anti-sneeze on it.
    BUDDYRAMMIT: The powder-coating place sand-blasted it. That's why I like using them. Saves me a TON of work cleaning things up.
    gmcburb1965: True enough. But for $192, I got it completely cleaned up and protected for life. That seems like a decent bargain to me!
    mrk5: Thanks!
    edit: I think I'm gonna downsize those pics a bit. I hate scrolling sideways.
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Anti-sieze on the bolts or the surface too? The bolts are ok to have anti-sieze on but anything that can act as a lubricant is probably a bad idea in that spot.
    The powdercoat looks awesome. I wish I would have been able to have that done to my axle before they were installed. They barely got a black coat of rustoleum & some orange on some of the other parts. With all the gunk, rock contacts, & road grim you can hardly tell I even tried to make it look good. :crazy:
    Harley
  10. goldwing2000
    goldwing2000 Guest
    Anti-seize on the surfaces, too. Just enough to keep them from rusting together. A thin film of lubricant isn't a problem, since friction doesn't keep the arm in place. That's the job of the cone washers!
  11. gmcburb1965
    Oct 29, 2005
    61
    Colorado Springs
    Agreed, great price!
  12. goldwing2000
    goldwing2000 Guest
    It's nice having a world-class powder-coating shop just around the corner. :D
  13. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Yes, but the friction keeps the arm from shearing the studs. The cone washer ensure the arm won't loose its friction preload even if the nuts come off. Kina like the design of a lugnuts taper.
  14. goldwing2000
    goldwing2000 Guest
    No offense but I seriously doubt that a thin film of lubrication is going to make the difference between shearing off Grade 8, 9/16" fine thread studs or not.
    The cone washers are not lock washers to maintain preload. That's what the lock nuts are for. The cones are there to eliminate lateral movement of the arm.
  15. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    what did you do with the rotors? just the outside surface? looks good. im a cheap bastard too, i just spray painted my chit with no prep work (i used undercoating) and it looks decent :)
  16. goldwing2000
    goldwing2000 Guest
    Scuff-sanded the shiny bits, painted the entire thing with high-heat paint (heavy on the non-braking surfaces, light on the braking surfaces) and then let the brake pads wear off the paint where they made contact. I figured that was the best way to get the most coverage.
  17. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Its your call on the anti-seize but I am just trying to promote the safe thing here. I doubt you will have a problem with it especially since you don't have crossover. I am just trying to point out a potential problem with something that is somewhat important like steering.
    Think of it this way. No lube is like your tires sticking to dry pavement. With lube is like your tires are trying to stick to wet pavement. They still stick but not as well. The thing trying to stick your tires to the pavement is constant just like the cone washers, your 5,000lb truck which doesn't change, just the amount of traction you get does.
    This pic is of my steering studs. The was not a failure due totally to lube but it was a factor.
    http://rides.webshots.com/photo/1149207763053352602WskNYA?vhost=rides
  18. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Okay, the cone washers make a zero clearance out of a bolt and a hole. There is always a little wiggle and lug nuts and cone washers remove that wiggle. The studs create a clamping force on the arm. This creates the friction that allows the arm to stay attatched.
    Do what ever you want, but I know how it was designed to be done.
  19. goldwing2000
    goldwing2000 Guest
    Well... everybody is entitled to their opinion.
