Shipping weights!
Discussion in 'General Parts for Sale' started by kennyw, Nov 13, 2002.
  1. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    I have an idea, lets post actual shipping weights for use with estimating shipping costs here.
    BODY/INTERIOR:
    Blazer Tailgate, Power Window, Glass, Hinges, Everything with crate: 194#
    Blazer rear glass with metal strip: 35#
    Pair of aluminum running boards for 77 Jimmy, including packaging: 25# approx 65" x 5" x 12"
    Pickup tail gate with full stainless trim panel and body molding trim on it: 65#
    1 complete set of pickup seatbelts: 10#
    Dashpad 81-87,91 AC: 16#
    Dash bezel with AC: 4#
    Wiring harness from 79 k-5: 14#
    Overhead console from 1989 suburban: 10#
    AXLES/DRIVESHAFTS:
    Corp 10 bolt rear axle in crate, complete from drum to drum: 400#
    Corp 10 bolt rear 30 spline shafts (pair): 40#
    Corp 10 bolt rear Complete 28 Spline spider set w/pinion pin and bolt: 5#
    Corp 12 bolt housing with caps and back plates only: 75#
    Corp 12 bolt complete with drum brakes: ???
    Corp 12 bolt Ring & Pinion plus install kit, all new in original box: 21#
    pair of Corp 12 bolt axle shafts in a box: 40#
    Corp 14FF complete axle w/ disc brakes: 400#
    Corp 14FF complete axle w/ drum brakes: 475#
    Corp 14FF carrier minus ring gear: 36#
    Corp 14FF carrier w/ ring, pinion & pinion housing: 80#
    Corp 14FF axle shafts (both sides): 33#
    Corp 14FF hub (1) with bearings: 23#
    Corp 14FF ring and pinion: 25#
    Dana 70HD, wide track unit from GM Dually pick ups,complete with drums and all brakes: 480#
    Old Eaton centersection, complete, in plywood box: 124#
    Front Dana 44 hub to hub, 8 lug complete on stout pallet: 415#
    Front Dana 44 shafts with u-joints & packaging: 36#
    Front Dana 44 inner axle shafts (one short one long): 25#
    Front Corp 10 bolt 8-lug complete w/ hubs, tie-rods, & arm: 414 lbs w/ pallet
    Front Corp 10 bolt Ring & Pinion w/ carrier (no spiders or cross pins): 33#
    Front 6 lug bearing hub, rotor & bearings: 37#
    Front 6 lug bearing hub (1): 13#
    D44/10 bolt spindle: 5# each
    (2) D44/10 bolt solid backing plates: 21#
    (2) flat top knuckles packed in box with styrofoam pipe wrap: 26#
    (1) 8 lug rotor w/hub, 1 backing plate, 1 spindle, 2 locknuts, 2 bearings: 54#
    8 lug hubs and spindles. No bearings or lug studs: 41#
    8 lug conversion set up backing plates out plus crate: 142#
    10 bolt warn premium locking hubs: 4#
    Front 10 bolt differential cover: 7#
    Front Dana 44 differential cover: 4#
    Front Dana 60 hub to hub w/ pallet: 550#
    Front Dana 60 hub to hub w/ full crate: 670#
    Dana 60 4-series (4.56+) open carrier: 27#
    1 Ford Dana 60 spindle in box: 8.5#
    Front Dana 60 bare housing wrapped in plastic: 145-150# depending on how bare
    Dana 60 Front DRW hubs, with wheel studs and attaching bolts in a sturdy cardboard box - 64#
    14bff and dana 60 front completed in the wooden military shipping crates...1150#
    2wd 1/2 ton disc spindle with rotor and caliper: 60#
    2 front drums (12"x2"), 1 set of brake shoes and hardware: 65#
    Stock front drive shaft: 22#
    Driveshafts from a 79 K-5 with a 203, front and rear in box stuffed with newspaper: 43.3#
    Wheels & Tires:
    hummer rims with PVC runflats: 42# each
    14x15 8 hole chrome/steel steel wheels: 40# ea.
    16x8 cast aluminum rims, no box: 21# each
    ENGINE & ACCESORIES:
    #2783 1963 cast iron holley GM intake & box: 35#
    Aluminum Elderbrock intake: 13#
    SBC .030 over pistons: 14#
    Quadrajet carb: 11#
    Power steering pump: 13#
    Complete TBI setup with intake, sensors, computer, harness, distributor, coil: 45#
    400 sbc: 466#
    454 long block minus intake manifold: 605#
    454 complete with accessories (starter, alternator, flex fan, pulleys, power steering pump, flywheel, carb, air cleaner, etc.) mounted in engine cradle bolted to pallet with plywood box built around it: 980#
    CAT 3208 v-8 diesel: 1200#
    CAT 3116 I-6 disel: 1500#
    Duramax 7800 I-6: 1180#
    TRANSMISSION/T-CASE:
    TH400: 135#
    TH700: 155#
    TH350: 120#
    TH350 regular case, no converter or dipstick in a 24x24x24 box banded to a 3/4" piece of plywood: 132#
    NP203 Range box w/ output shaft: 87#
    NP203 Range box w/adapter and output shaft for a 465 in a crate: 131#
    NP205 for TH400 without adapter: 135#
    NP205 for SM465 w/adapter and shifter on pallet: 170#
    NP208 without adapter: 78# in a well packed box
    241 NP, just case, No extras in a wood box made from ¾ plywood: 120#
    TH400-NP208 adapter: 13#
    SM465-NP208 stock cast adapter: 26# includes strong cardboard box
    SM465-NP205 figure-8 adapter: 21#
    SM465 & NP205 complete including shifter's on a pallet: 402#
    SM465 & NP241 w/hydro clutch, flywheel, pedals and brackets: 413#
    TH400 & NP205 assembled w/crossmember on pallet: 403#
    Hydraulic Bellhousing, Pedal assy (Brake/clutch/mount), Master/Slave cylinder: 35#
    Stock NP241 slip yoke drive shaft: 15#
    Brace from bellhousing to t-case: 4#
    4 spd shifter boot and trim ring: 4#
    FRAME & SUSPENSION:
    1988 K5 Blazer frame with all crossmembers and swaybar: 380#
    Pickup Frame, longbed 73-87 2wd w/ crossmember, minus all bolt-on suspension parts: 200#
    Class 3 Reciever Hitch: 40#
    Factory Rear spring, front perches: 36#/pair with small amount of frame and brace attached
    52" stock rear springs w/ 4 leafs and overload: 49# each
    8" Superlift front springs: 55# ea
    8" Skyjacker lift kit with shocks, fr & rear springs, steering arms, & u-bolts: 250#
    2 ORD zero rates with hardware: 8#
    4-6" lift shocks packaged in one box: 24#
    Set of ORD shackles and non greasable bolts, no bushings: 6#
    Flat transmission crossmember: ???
    Double hump transmission crossmember: ???
    "S" shaped crossmember: 16#
    2wd steering box with pitman arm: 37#
    steering shaft (between p/s box and steering column): 5#
    MISC:
    Wiper Motor: 7#
    warn XD9000 with fairlead and controls: 70#
    Crated Warn 8274 winch: 128#
    Warn 16.5ti winch w/cable and controller in box from the factory brand new: 110#
    Mounting plate, w/ cable hook and remote: 35#
  2. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    great idea! /forums/images/graemlins/thumb.gif
  3. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Dana 60 Hub to hub: 554 Lbs with pallet! /forums/images/graemlins/eek.gif
  4. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    It was 800lbs for the Dana 60 and 14 bolt FF (with disc brakes) I got in a crate/frame....
  5. kennyw
    Jun 9, 2002
    13,223
    94
    Re: Shipping weights! *DELETED*
    Post deleted by kennyw
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    12 bolt housing with caps and back plates only= 75lbs,
    2wd 1/2 ton disc spindle with rotor and caliper= 60lbs
    longbed 73-up 2wd pickup frame with auto crossmember and minus engine cradle and stand and minus all bolt-on suspension parts= 200lbs
  7. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    NP205 for TH400 without adapter 135#
  8. kennyw
    Jun 9, 2002
    13,223
    94
  9. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    great post !!
    465-208 stock cast adapter #26 includes storng cardboard box
    8 lug conversion set up backing plates out 142# includes home made wooden box made from 1/2 " ply wood and 2 2x4 for the bottom so the fork lift can pick it up ;-)
  10. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    can this be made a sticky?
  11. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    203 Range box w/ output shaft 87lbs.
  12. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    NP205 for TH350 w/2 crossmembers, skidplate, and adapter on pallet = 180#
  13. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    NP208 T-Case without adapter: 78lbs in a well packed box.
    John [​IMG]
  14. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    2wd steering gear box....32lbs /forums/images/graemlins/thumb.gif
  15. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    203 Range box w/adapter and output shaft for a 465 in a crate - 131 pounds. Cost $63 to ship from Illinois to NC via FedEx.
    465 version 205 w/adapter and shifter - 170 on homemade palet. Cost to ship from NC to CA is $68 via Forward Air.
  16. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    #2783 1963 cast iron holley GM intake, 35 lbs boxed,
  17. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    14b carrier minus ring gear= 36#
  18. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    2 flat top knuckles packed in box with styrofoam pipe wrap.....26lbs /forums/images/graemlins/thumb.gif
  19. Rooster53
    Rooster53 Registered Member Premium Member
    May 8, 2000
    41
    CT
    1988 Blazer Tailgate with Power Window and crate 198 lbs.
    From Texas to CT $69.00 forward air
  20. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    hummer rims with PVC runflats = 42# each it was $57.12 to ship all 4 rims in boxes 155 miles
