shock bolt question
Discussion in 'The Garage' started by bad_bo_ti, Feb 21, 2003.
  1. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    dont worry i searched first!! /forums/images/graemlins/rotfl.gif anyway i am making a new cross member for the rear to relocate the shocks. i am making one similar to this [​IMG] is there a certain bolt/sleved bolt i need (where do i buy them), or could i use a regular bolt, of would i be better off using a smaller bolt with a piece of tube as a sleeve? thanks for the info in advance. Chris
  2. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    I asked myself that same question right before I saw this post. Anybody know?
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    what size hole??? the p-19 rancho bolt uses a 5/8" hole. the #146029 ( or is it 140629???) uses a 1/2" hole and is made by gabriel.
  4. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    Either way is OK as long as you don't squeeze the grommet too much. If you use a bolt without a sleeve use a lock nut.
