Shock Effectivness?
Discussion in 'The Garage' started by trollporter, May 19, 2004.
  1. trollporter
    trollporter 1/2 ton status
    Feb 29, 2004
    518
    Lady's Island, SC
    I ask this because I'm thinking about mounting my rear shocks to the spring plates and run ford shock towers directly above the axle on the outside of the frame. I know that I will have to /forums/images/graemlins/hack.gif the floor for the towers and I know that the suspension cycles foward when flexed so I'm probaly going to have to find the shock towers that are on the newer f250's that have a stud setup that will allow the shock to swing foward as the suspension cycles. I'm just not sure if the shocks will be very effective mounted vertically. /forums/images/graemlins/1zhelp.gif
  2. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,066
    190
    Colorado
    That is the shocks most affective position. They loose their ability to dampen spring forces as you lay them down from vertical.
    This method works very well. Just make sure that the shocks can't hit the frame during articulation. /forums/images/graemlins/thumb.gif
  3. trollporter
    Feb 29, 2004
    518
    Lady's Island, SC
    Thanks miniwally /forums/images/graemlins/waytogo.gif. I didn't think about the shocks hitting the frame /forums/images/graemlins/thinking.gif.
