shock length?
Discussion in 'The Garage' started by big jimmy 91, Mar 26, 2004.
  1. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    With a 4" lift (52"springs up front , shakel flip rear ) , what length shocks are req.
    And do they mount in stock position?
    I am just trying to get my parts req. list together.
    Also I was told that my front dr. s. will hit the "Y" pipe is this true
    P.S. its a 91 full size
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/ears.gif
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Don't know about the other stuff, but yes, if your exhaust is in it's stock position, the front D.S. will rub the crossover pipe, but i still have not had mine rerouted, it has rubbed, but nothing serious, the same with Pauly383k10, same setup.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Yup I rub a little bit . Mostly front driveshaft to y-pipe, some tire to inner fender if swaybar disconnected. No biggie, when I have time off on a weekday I will get y-pipe moved. Most places will have the numbers already for lifted trucks shocks. As for myself, I run gabriel #g63438 in rear (autozone stocked) and moved my rear 4 inch lift kit shocks to front. Seems as my shackle flip with good rear springs sits up higher in rear and kit shocks were too short. Hope it helps./forums/images/graemlins/thumb.gif
    BTW the gabriel shocks are less than 22 bucks, which is way cool /forums/images/graemlins/waytogo.gif
  4. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I think your best bet would be to do the ford shock tower mod in the front then just measure for shock length. When measuring you want to make sure the rubber bumpers, if you have them, stop the axle on compression before the shock itself bottoms out. Go as long as you can. Summit is running a special buy 3 pro comp shocks get 1 free so you could get a full set of ES9000s for just over $100.
