Shock Lengths
Discussion in 'The Garage' started by PROFESSORSK5, Mar 16, 2004.
  1. PROFESSORSK5
    PROFESSORSK5 Registered Member
    Dec 19, 2001
    81
    So California
    I need to replace the shocks on my 89 K5 blazer with a 6" suspension lift and 35 (soon to be 36" or 37")tires. I have been looking at Bilstien 5150 series shocks. The problem is they are sold by how far they expand not by what vehicle they fit on. Does anybody know what size shock I would put on my truck? /forums/images/graemlins/k5.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Depends on what you're running for mounts. There really isn't much in the way of long travel shocks for stock mounts, especially up front.
    Before you spend a dime on shocks, get yourself some Ford towers up front. /forums/images/graemlins/thumb.gif
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Cycle the suspension and find out what shock length you need.
    There is the highly technical, take out all of the leaves except the main leaf, replace with a wood block the same thickness as the leaves you took out, then jack the vehicle up and measure.
    For something not as hardcore as a race truck, jack the vehicle up, let the axle droop to it's full potential and measure that way. It's not hard, but you will probably have to get a shock that is just a tad short at extended length if you are using the stock shock mounts. Nothing you can do about it except be careful or run limiting straps.
  4. PROFESSORSK5
    Dec 19, 2001
    81
    So California
    What I did is call Bilstein's tech department, explained my problem and they gave me the correct part numbers for the shockes. I only ordered the rear shocks though. I have a tow package blazer so I already have four shocks up front, but I would like more info from you on the Ford shock mounts. Thank you for responding so quickley and sorry it took me so long to write back.
  5. PROFESSORSK5
    Dec 19, 2001
    81
    So California
    Thanks also to Bubba Ray for your suggestion. If I would't have gotten any answers from Bilstein, I would used you sugestion. Thanks
