shock location question when installing 14 bolt ff in a half ton?
Discussion in 'The Garage' started by MRBIGBLOCK, Mar 15, 2003.
  1. MRBIGBLOCK
    MRBIGBLOCK 1/2 ton status
    Jun 25, 2001
    472
    paragould arkansas
    will be putting a 14 ff from a 78 2 wheel drive 3/4 ton in a 86 short bed 1/2 ton 4x4, will the shocks bolt up? or will some modifacations be in order? /forums/images/graemlins/crewcab.gif thanks guys!!!
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I believe the shock mounts on the 2wd 14 bolt FF hang two inches lower. So, your current shocks will bolt up, but you won't get as much travel out of them.
  3. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    heavy4x4 is correct, the shock mounts are 2" lower on the 2wd version.
