shock mount pictures.
Discussion in 'Pacific Region' started by Gold Rush, Nov 11, 2002.
  1. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    Mike was requesting these...
    For the upper mounts I boxed in the frame and then added a 2"X2" 1/4" wall square tube for a cross member. Then took a pair of rear upper shock mount bolts and whacked off the one end and welded them to the cross member.
    The bottom mounts were made from the same type shock mounts the top were. I took some left over 2X2 and cut it down the center to make two c channels. Then welded them to the axle tube. Then welded the shock bolts to the c channel.
    <font color="red"> P.S. the rear shocks are 36" long Rancho 5000's. If your interested let me know cause I can get some more. </font color>
    David
    /forums/images/graemlins/usaflag.gif
  2. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Thank you David...
