shock mount question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Jan 25, 2001.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I put on my front shocks, but forgot to put in the metal bushing thing that goes in the rubber bushing on the f. So, when I used the impact to tighten the bolt, it distorted the sides of the shock mount together. I'm talking about the axle side, not the frame side.
    This isn't a big deal, I suppose, but I'd like to open the gap back up so I could install the metal sleeve in the shock bushing like I was supposed to. I'm at a loss for what to use to get in there and force the shock mount back out all the way. It's thick metal and a prybar didn't even touch it.
    Any ideas?
    -- Mike
  2. JST12
    JST12 1/2 ton status
    Aug 29, 2000
    192
    Garland, TX
    Hey MIke,
    I had an idea. What about putting a bolt through the mount with two nuts and washers on the inside of the mount. You could turn the nuts with an open end wrench and force the edges of the mount outward. Good luck,
    JT
  3. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    You can also use threaded rod if the bolt threads don't span the whole width of the mount.
    <font color=green>Joe Angelicchio
    86 Jimmy 4+3, 35-&gt;39.5 tires,4spd
    </font color=green>
  4. Mr Red
    Mr Red 1/2 ton status
    263
    Washington, DC Metro Area
    I had a similar issue for the bottom mounts on the rear axle. I used a 5 pound sledge hammer-light taps. I suspect if you try to do all the movement / correction @ once, the metal will give out-either immediately or while you're on the trail. Be gentle, mine's still working ok.
    I do like the idea of using opposing bolts bolts though.
    Good Luck,
    <font color=red>David, '86 & '91 K5</font color=red>
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I just get out the 12-inch adjustable wrench, adjust it down to where is just slips over the mount tab, slip it over and pull. Quick and simple. [​IMG]
