Shock Mount
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kpanza, Dec 19, 2000.
  1. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    When I was putting in my new 14 bolt and the new lift springs last night, i noticed for the first time that the rear drivers side shock mount was cracked! This was after I took the old shock off, there it was! It actually moved when I took the shock off...just want to make sure that it is all right to just weld that mount back up and forget about it? Is this a common point for breakage? It doesn't appear to be the best though out GM design, they just riveted the mount onto the frame rail, very weak in my opinion. But if I get it welded up it will be fine, right?
  2. Truckfan2
    Truckfan2 1/2 ton status
    Apr 10, 2000
    343
    Northern IL
    That's what a previous owner did to my truck and it seems to work fine. I dunno the rules to welding to a frame though...
    Have been stuck (once) as of 8/12/00
  3. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    mines busted, i got a new one at the dealer for 12 bucks, dont know how im gonna put it on yet, its kinda tight there, and im trying to avoid dropping the tank. any ideas?
    shaggyk5
    aint nuthin in the world like a heavy chevy!!
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I broke mine, and got a new one for $9 cause I'm friends with a dealer, but I just got it welded on for ten bucks, and it hasn't caused any problems, been wheeling twice with it like this.
    90K5
  5. shaggyk5
    1,610
    SE pennsylvania
    did you drop the tank to weld it?
    shaggyk5
  6. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
  7. shaggyk5
    1,610
    SE pennsylvania
    the cross bar and 9012's come after the lift and the tires and the rest of the floor replacement and................
    shaggyk5
  8. KILLERK5
    KILLERK5 1/2 ton status
    Oct 19, 2000
    108
    Aurora, Colorado
    Mine cracked also. I had it welded about six months ago. I've been four wheelin plenty of times since with no problems.
  9. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    Had the same problem with mine. I rewelded it but it eventually broke. Dealers sell the replacement for about $12. You have to remove the gas tank skid plate and the gas tank. Not too hard the hardest part is drilling out the old rivets, piece of cake if you have a touch. it can easliy be done in a weekend.
  10. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    To weld it, you dont really need to drop the tank, just spray some water on it before and after you weld.
    90K5
