shock mounting issue
Discussion in 'The Garage' started by MTChevy, May 26, 2006.
  1. MTChevy
    MTChevy 3/4 ton status Premium Member
    May 6, 2005
    7,141
    78
    Great Falls, MT
    I got some hydro TC shocks when i bought my lift kit a while back. The shocks in the rear fit perfectly with the 10 bolt axle. Now i have switched to a 14BFF rear end. The shock on the rear of the axle fit fine but the shock on the front side. (drivers side) hits the axle tube on the lower shock mount. I looked at the shocks and it looks like the mounting point on the lower mount needs to come forward. Its a stock placed mount but it looks like it was welded a little lower down to clear the brake line. Am I just going to have to refab the mount or is there a different way to do this? I'm sure im not the only person who has had this problem.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    The same thing happened when we installed a 14FF in a friend Blazer. We just knocked off the axle mounts and welded new ones on.
  3. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    Sorry to hijack, but is it safe to weld to the axle tube without removing axle shafts and gear oil?
  4. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Yep I had to move that mount on mine as well as it strted to dent the shock body after use. Yeah it's fine to weld on the axle as is.
  5. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    Didn't want to start a new thread for this so I'm bringing this one back up.
    I'm having the same problem, but with the mount on the rear of the axle. Can I run the shock upside down, with the tube up top? Any ill effects of running it like that?
  6. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Not unless the destructions that you got with the shocks said they can be ran in a different position. The reason being is that shocks tend to be made to be ran a certain way (tube up, tube down) and changing it up with a shock that isn't meant to be switched will screw up the valving.
