shock mounting when using offset 0 rates
Discussion in 'OffRoad Design' started by Blazinaire, Apr 18, 2002.
  1. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I have the stock upper shock mounts (1 facing forward, 1 back). I plan to use the 0 rates to relocate the rear axle 1 1/2'' back before I have my c/v shaft made. The forward facing shock would be extended a bit further and the rear facing one would get compressed. Is this something that I should worry about? Should I relocate the upper shock mounts?
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    yes you should.../forums/images/icons/wink.gif/forums/images/icons/laugh.gif
    seriouly though I don't think the 1.5" will make a difference. Although you could relocate the shocks and have that piece of mind that they are where they should be,LOL.
  3. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I talked with Stephen a few weeks ago about this same subject. He said it is not a big deal to worry about it.
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    It will have some effect but not huge. If the shocks are marginal you might have problems but otherwise it should be OK.
