Shock Mounting
Discussion in 'The Garage' started by RSNHELL, Jan 25, 2005.
  1. RSNHELL
    RSNHELL Registered Member
    Jan 17, 2005
    53
    SANTA ROSA,CA
    does anybody know how much compression/drop ratio i'll need on a 10" TRAVEL shock. I'm thinking I should just split it in half ,5'' of comp. and 5" of drop. also what would be the minimum comp. distance I could go.(stock distance?) THANKS
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    measure from the bumpstop to the axle. take that number, add 1/2-3/4" to it and thats the compression of the shock. figure out where bottoming out on the shock is and add the compression needed and mount at that height.
  3. RSNHELL
    Jan 17, 2005
    53
    SANTA ROSA,CA
    Right on, that makes perfect sense. Thanks for the help, sometimes I make things more difficult than they are. I appreciate it. RICK
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    A mod of Big83's technique is that I measure from the axle to 1/2 way thru the bumpstop, and add 1/2" to that. Most bumps will compress to half their height when you hammer them hard.
