shock mounting
Discussion in 'The Garage' started by sf_wood, Apr 20, 2005.
  1. sf_wood
    sf_wood Registered Member
    Apr 4, 2005
    70
    san francisco ,ca
    I just ordered front shock towers(p#e5tz-18183-a)from ford 11.95 each,good price.My question is what position do i mount them in? I have a 1977 K10 (465/205/d44/14bff) also my rear lower shock mounts hang below axle tube how do i reposition them, what about upper mounts.
    just so you know , I have COMPLETE ORD 6" lift with all the goodies. :saweet:
  2. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    You can mount them in whatever position you want as long as the shock stays parallel in the mount during full suspension cycle. I broke the eyes off of 2 shocks because one mount was angled back a bit too much. Once I corrected the angle, I've had no problem.
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Set them so that at full stuff you can't quite bottom them out. I figure that the bumpstop will compress to half it's normal height in a really hard hit. If you tend to be hard on bumpstops them I would set them so that at metal to metal they are 1/2"-1/4"' shy of fully compressed. Don't forget that in articulation the axle will come up further at the damper mount than at the bumpstop.
  4. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
