shock mounts on k5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by down4thakrown, Jul 14, 2004.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    any one have a good idea of fixing the shockmount that is rivited a top the rear frame of a k5? Not much left to weld too. /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    [​IMG] /forums/images/graemlins/woot.gif /forums/images/graemlins/waytogo.gif
    theres one idea, although I do have a box of lowers I'm out of the upper crossmember which does you alot of good /forums/images/graemlins/doah.gif
  3. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Where do you mount the shocks on the rear end to work with that crossmember??? Just weld new shock mounts on top of the axle??
    -Chris
  5. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Also, you can barely make out the lower shock mount on the axle. I used a 3" spring perch that you can by at a racing shop. I think they are about $5-$10. Just cut it in half, drill one hole and weld it on.
  6. blueblaze
    blueblaze 1/2 ton status
    Dec 4, 2001
    274
    Salt Lake City, UT
    Are you by chance selling the upper mount's?
  7. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    DP, are you using any body lift and what shocks are you using?
  8. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    I don't normally make them to sell, but we can work something out.
    Shoot me an email @ dpalms@bigzoo.net and we can discuss.
  9. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Nope - no body lift and I am running Rancho 9012s.
    It may look a little deceiving, cause I have 9" of suspension lift in the back. I wanted the shocks to be separated on top as far as possible for more lateral support.
  10. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    It looks like the distance from your bump stop to the axle tube is far greater than the amount of shock shaft that is showing. Are you bottoming out on the shocks or the bumps?
  11. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Neither. The 4" bds rear springs are pretty stiff. Here's about the most flex I can get out of the springs. I will see if I can find a pic of the shocks. I think I still had 2" of shaft showing on the shock. /forums/images/graemlins/dunno.gif
    btw, those are the factory bump stops...
  12. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    the lowers I have are in front of the crossmember. they mount to the front or rear of the axel.
  13. BAJA_BLAZER
    May 17, 2001
    517
    San Diego, CA
    Put a small Zip Tie tightly around each of the shock shafts and push it to the bottom. After your next trip out wheeling, check them and you will know exactly how much shock travel you have used. /forums/images/graemlins/waytogo.gif I realized that they are the stock bumps and assume that they are not hitting the axle tube, because if they were it looks like they would crush your brake lines. Hard to tell exactly from the pictures, but looks like it.
  14. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Good idea about the zip ties. I must do that tonight. Yeah, those bump stops will never touch anything. I thought about taking them off, but never did...
