shock placement question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by one, Sep 26, 2002.
  1. one
    one Registered Member
    Aug 31, 2002
    28
    redwood city california usa
    Is a 90 degree angle to the axle better than a 60 degree angle for a dual shock setup? My k5 comes stock with duals angling back...whats up? Planning longer travel shockhoops(90degree)with new lower mounts or extended shock mounts(f150 style)in stock position.
    Any help greatly appreciated.
    Thanks!
  2. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    I think Greg72 has this set up on his 1st Gen. (Stomper) Check with him! Good luck!
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    What kind of wheeling do you plan on doing?
  4. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Benjamin,
    A shock will lose effectiveness as it is angled....I have all the numbers here somewhere....but basically, the more upright you can keep the shocks, the more damping they can provide.
    By the time a shock is angled to 45 degrees, it is only 70% as effective as one that is mounted at 90 degrees.....
    There are practical limitations to where the shock can physically fit, but I always strive for as "vertical" as possible. /forums/images/icons/cool.gif
  5. one
    Aug 31, 2002
    28
    Thanks! I'm going for the sttraight up placement with hoops. Wish me luck!
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    It also depends on what "rate" you want from the shock. This is based on how the shock is valved, how stiff your springs are, how much sprung/unsprung weight you have, and the wheeling you do. What I'm trying to say is that you don't always want every shock vertical in every application. For instance, I have 5012s all the way around my rig. There is more weight in the front and I want more control up there so they are mounted about 30* off vertical (also limited options up there anyway). In the back, I have less weight and I basically only want the shocks to prevent pogo effects, so they are angled forward about 45*. With softer valved shocks (50xx Ranchos are notoriously stiff) you would achieve the same results with less angle.
    The results also depend on how the shocks are oriented with respect to forces. For instance, rear shocks with the top mounted in the center (as is very popular around here) provide very little roll control, but it does allow a longer shock to be used as well as providing an *effectively* longer shock. I mount mine with the top on the outside of the frame, kicked forward instead of inside. Same shock “rate” but better roll control.
    So, the real answer is, it depends…
