Shock Poll- What are you running/Have you run?
Discussion in 'The Garage' started by Swanson52, May 4, 2003.
  1. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    <FORM METHOD=POST ACTION="http://coloradok5.com/forums/dopoll.php"><INPUT TYPE=HIDDEN NAME="pollname" VALUE="1052066648Swanson52">
    What Shocks are you running or have you run?
    <input type="radio" name="option" value="1" />Rancho RS5000
    <input type="radio" name="option" value="2" />Rancho RSX
    <input type="radio" name="option" value="3" />Rancho RS9000
    <input type="radio" name="option" value="4" />Pro Comp ES1000
    <input type="radio" name="option" value="5" />Pro Comp ES3000
    <input type="radio" name="option" value="6" />Pro Comp ES9000
    <input type="radio" name="option" value="7" />Pro Comp MX-6
    <input type="radio" name="option" value="8" />Bilstien 5100
    <input type="radio" name="option" value="9" />Doetsch Tech
    <input type="radio" name="option" value="10" />Skyjacker Hydro
    <input type="radio" name="option" value="11" />Skyjacker Nitro
    <input type="radio" name="option" value="12" />Superlift Hydro
    <input type="radio" name="option" value="13" />Superlift Nitro
    <INPUT TYPE=Submit NAME=Submit VALUE="Submit vote" class="buttons"></form>
    What did you think of them? What would you run otherwise? The best luck of the shocks I have run has come from the Skyjacker Nitros. Great shocks, IMO (but have never run adjustables, Bilsteins, or DT's).
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    RS9112's in the rear (14")
    and 5000's in the front, front will be redone with 9012's as soon as I can get some more $$$
  3. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    rs5000s, rather stiff wen i had the dual shock setup on front removed one and theyre not bad now. now theyre just too short for my rear mounts. /forums/images/graemlins/frown.gif
  4. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    rANCHO 9000S IN THE FRONT AND ES 3000 IN THE REAR. Oops caps lock.... too late /forums/images/graemlins/crazy.gif
  5. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I've ran the Rancho 5000(they suck), currently have 9000 on the rear. I like the adjustability of the shocks, the ride isn't as harsh.
    My next set of shocks will be the Bilstein 5150 /forums/images/graemlins/thumb.gif
  6. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Hey!!! You don't have Eliminators in there???? /forums/images/graemlins/rotfl.gif I'm running those right now, they aren't so bad, but I'm sure RS9000's would be much better.
  7. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Sorry....I knew I missed one or two. /forums/images/graemlins/wink.gif
  8. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    What, in your opinion, makes the Bilstein superior to the RS9000?
  9. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Have run RS5000s and ES3000s, running RS9000s now but will move to the Bilstien 7100s next year. </font>
  10. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    The RS9000 is a mutliple tube design shock, therefore it is much easier for the fluid to foam and render the shock useless. The Bilstien's use a Mono-tube design with a dividing piston between the fluid and gas. Therefore the oil cant foam up and it is much harder for the shock to fade and it can be run in any position unline the multiple tube design shocks.
  11. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    damn, u guys must all be rich. RS9000s are just bank.
    j
  12. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Would that make the Pro-Comp MX-6 the best of both worlds then? Monotube design with adjustability?
  13. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    It all depends on the type of wheeling involved.
    The difference between the two shocks are what they are. The Ranchos are a twin tube shock while the Bilsteins are a mono-tube shock.
    No big deal for most people who just need a shock to bounce around the rocks or do some slow speed wheeling. But for doing the speed stuff, a mono-tube shock is superior due to it's design. What happens is that the piston builds heat as you are going down the road bouncing around. A mono-tube shock dissapates heat faster than a twin tube shock. The heat build-up induces shock fade (I could say something here, but I won't /forums/images/graemlins/rotfl.gif) and soon the shock is a useless item unable to do it's job. That's why on the off road race rigs, you will see a big diameter shock with a resevoir. More oil to take on more heat.
    Here's an article that will 'splain things a little bit more Shocks.
    Now with that being said, it all depends on the wheeling one does. With that infomation in hand, then a decision on a shock can be made. The 9000's are a very good shock and as stated above, I have them on my truck and I've liked them. Unfortunately, for what I want to do, they are no good for me so I have to step up in the shock department.
  14. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    I don't know. I haven't read too much about it, though I do know that it's a mono-tube adjustable shock that with those features, should be the cat's meow for us low buck peeps.
    Ya know, it's kind of a hard decision to make. On one hand, here's Pro-Comp coming out with this shock, but the thing is they have no reputation for shocks. All of their prior stuff has been twin tube. On the other hand, Bilstein just comes out with the 5150. Their reps say the 5100 is great for someone like me, but now there is the 5150 with the resevoir........And they have the reputation in the mono-tube market. Both shocks are about the same in price, so it's a hard decision.
  15. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    procomp es3000's, they ride a lot better than my previous shocks, but anything would ride better than the ones i had before, they were monroe heavy duty, same shock a 3/4 ton or 1 ton truck might run.
  16. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    Well right now I have Trailmaster SSVs in the front and stock Ford F350 rear shocks in the rear. /forums/images/graemlins/frown.gif Plan on King 2.5 x 14 remote resv. in the fall /forums/images/graemlins/thumb.gif
    Eric /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  17. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Actually I have no shocks on right now but I do have 4 9012's still in the box's waiting to go on. Before that I had a set of Tuff Country shocks /forums/images/graemlins/crazy.gif that I got on a deal with my lift kit. On my old lift I had Rancho 5000 Harsh Rides, but back in the day when I put on My first lift it was the old Rugged Trail Nitro Cells.
  18. balzackks84
    Aug 22, 2002
    1,344
    portland, oregon
    j
    Not if you work for a distributor /forums/images/graemlins/thumb.gif
  19. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    RSX up front (love them) and none in the rear. . . waiting for the brackets to be made for rea, then i'll put the dual 5000s back. . .want something softer with the stiff superlift springs. . .
  20. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    9000's also /forums/images/graemlins/grin.gif
