SHOCK POLL
Discussion in 'The Garage' started by CHEVY 4WD, Mar 8, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    <FORM METHOD=POST ACTION="http://coloradok5.com/forums/dopoll.php"><INPUT TYPE=HIDDEN NAME="pollname" VALUE="1047144815CHEVY 4WD">
    SHOCKS
    <input type="radio" name="option" value="1" />NO ADJUSTING
    <input type="radio" name="option" value="2" />SELF ADJUSTING
    <input type="radio" name="option" value="3" />MANUAL ADJUSTING
    <INPUT TYPE=Submit NAME=Submit VALUE="Submit vote" class="buttons"></form>
    I have been looking for some shock(I want to run dual fronts single rears) So in the front I wanted somthing like a RS9000 but there dont come cheap so I was looking around and sal the self adjustings arent bad in price but dont know how they work, also what other brand makes a self adjusting shock? and Ill probably run RS5000's in the rear
  2. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    unless you plan on doing desert racing or something, dual shocks up front are a waste of money. Shock technology has advanced quite a bit since the days when K5s came with dual shocks. I know for a short while i had dual RS5000s up front... omg, WAY to stiff... even when i took 1 off each side it was still bad. I would avoid rs5000s like the plague now... just to stiff imo. DT8000s are way better shocks. they are non-adjustable... but they only cost half what RS9000s do.
    j
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Dt 8000's is DT Doestech? where can i get these? can i get them as long as a 9012 would be?...........
  4. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Any one run rancho RSX?
  5. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    Bilstein makes some good stuff, the 5100's are pretty reasonably priced.
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Look into Gaberial LT with VST shocks. They are reasonably priced (30.oo ea) they work good on or off road.
    I have the dual shock set up and replaced my RS 5000s with Gabrials and couldent be happier /forums/images/graemlins/thumb.gif
    The RS5000s were way too stiff. My K5 handles/rides way better with the Gabrials.
    If you are going to stay with the dual set up make sure you buy shocks made for the dual set up. Putting on 2 shocks made for single shock applications will be too stiff.
    Shocks made for dual applications are made special. They have have softer dampining rates and are made to work together.
